Switched 12v
DoubleV
2,154
406
83
Medina Ohio
the harness for the computer that came through the fire wall on the passenger for the computer is in a box next to my car. I put on a holley and a msd ignition set up
So if all the ECM wiring under the dash is still intact, then you have a 12v source at the connector that formally plugged into the ECM. Just run a wire from that connector out through the hole in the firewall.
H/O84
181
44
not quite sure what wires you are referring to but there are no wires where the ecm used to be anymore
5,717
12,241
I know this is a bit of a hyjac, and I am sorry. Does anyone know where I can tap into for a keied power that is off while starting? My knock gauge needs to be off while cranking they say. I can not test for one because my car is torn apart right now.
84 mentioned he had a kit that ran off from the alternator - which will work well also.
Zach,
You should be able to steal it from the radio, seats, heater, rear window defroster, etc. Basically anything that goes dead when cranking.
565 and 454 - I understand the system you guys are employing. And it will work great, but the point I was trying to make (and I should've been clearer) is that you want the pump to shut off when the motor is off in case of an accident and to save the pump from running of the key is on and the engine is off. I attempt to make all of these systems as idiot proof as possible so that my wife could hop in and move it or drive it in an emergency. Of course I'm sure that she could never manipulate the ratchet shifter lol.
9,619
12,709
Wiring in an oil pressure switch works in a similar manner but kills power to the pump when there is no oil pressure, what will kill power to the distributor when something happens?
One wire goes to the pump, one to the start circuit, and the other to the ignition circuit. So, when there is no oil pressure, the switch connects START to PUMP, and as soon as you start cranking it runs the pump. When the oil pressure comes up, the switch connects IGN to PUMP, for normal running. When oil pressure goes away it again connects START to PUMP, and disconnects IGN from PUMP, so the pump shuts off.
Brown at the ignition switch is accessory that drops out on start.
DoubleV
2,154
406
83
Medina Ohio
not quite sure what wires you are referring to but there are no wires where the ecm used to be anymore View attachment 83891
You need to find #29. Find the pin that's got the 12v ( pin C I think ) and run a wire from that pin out the rubber grommet you show in your pic.
Note, one of those pins is also a ground which needs to be grounded ( pin A or U I think ).
DoubleV
2,154
406
83
Medina Ohio
That is what I recall doing in my car at least. Use it to power both my electric fuel pump relay and electric choke. Also running wire from pin P for converter lockup.
H/O84
181
44
That way seems like alot more work. I wires from ign on the fuse box to a toggle switch then connect that to the relay. That way I have full control by either key on or toggle switch on. I like it better
H/O84
181
44
where is pin P I need to wire my converter lock up next
