Switched 12v
9,619
12,709
Don't bother going through this needless complexity. Your carbureted engine can run for quite a while just off the fuel in the float bowls. How do I know? Because on more than one occasion I have hopped in my car, started the engine, and driven away... when I forgot to turn on my electric fuel pump (controlled by a hidden switch).
I was describing this for the OP if he was running the pump directly off the fuse panel without an on/off switch so in that case the pump would be on whenever the ignition key is turned on so using the oil pressure switch as the trigger would eliminate the pump running until the engine was actually running since it would start without needing to prime the carb..
Like you I prefer to just turn the pump on with a switch and if you forget the car will remind you some enough plus as you stated it can be used for added security also.
454GrandPrix
429
818
Lehi, Utah
Okay, that makes sense.
In my case, my pump will activate as soon as I key to the ON position, even before I crank the engine. This has not caused me any problems, though.
DoubleV
2,154
406
83
Medina Ohio
You want to do a clean job with no splicing, then run a wire from your ECM connecter by the passenger side kick panel and out the hole in firewall into your engine compartment.
9,619
12,709
The only problem with that is a majority of people that are adding electric fuel pumps have most likely already eliminated the ECM and related components.
DoubleV
2,154
406
83
Medina Ohio
That's the point. No computer but all the wiring under the dash is still intact which means you still got a fused 12v source at the end connector that USED to go to the ECM.
Remember, the computer stuff's got 2 main harnesses; one under the dash ( which stays ) and one in the engine compartment ( which is removed but hopefully not just cut because that's butchery.... ).
9,619
12,709
I must have mis-read what you were saying to do.
I did remove all of my wiring going to the ECM on my Monte but I agree most people won't go that far.
H/O84
181
44
Ecm is gone and the wiring harness for it is completely cut out I think I'm going to run from the ign on the fuse box to a switch then to the relay. I'm using the racetronix hot wire kit so the harness bolts to the alternator, has an in line ruse and goes to the relay
DoubleV
2,154
406
83
Medina Ohio
Under the dash wiring has all been cut out or just the wiring under the hood?
Turbo Zach
2,534
5,874
I know this is a bit of a hyjac, and I am sorry. Does anyone know where I can tap into for a keied power that is off while starting? My knock gauge needs to be off while cranking they say. I can not test for one because my car is torn apart right now.
H/O84
181
44
the harness for the computer that came through the fire wall on the passenger for the computer is in a box next to my car. I put on a holley and a msd ignition set up
