So someone told me that if you have a car that has a oil burning issue (say blow-by on the rings) and it smokes with conventional oil, you can switch to synthetic and it will not be as apparent.
That is to say that the way they described it is synthetic oils burn almost "invisible" and there's not much visible smoke. Sure, your car will still by-pass/burn the oil, but the smoke cloud coming out of your exhasut will not be visible or at least very diminished.
Is that true?
Is that true?
