T5 Questions...
Re: A body clutch pedal and bellhousing
You can measure where the shifter will be. My GP is parked for the winter so I can't measure it for you but I think the position of the stick will be ok for a bench seat. What other parts do you need for a conversion?
pontiacgp said:
You can measure where the shifter will be. My GP is parked for the winter so I can measure it for you but I think the position of the stick will be ok for a bench seat. What other parts do you need for a conversion?
I need everything haha, but as far as the distance i'll measure the car tonight and let you know
ok thanks! i'll let you know about the measurements and go from there. About the "E"Brake i was also going to remove the pedal, but i was toying with the idea of trying to use a Fiero handbrake because of the bench
on an automatic I don't mind not having an e brake but with a standard I wouldn't drive it without an e brake
pontiacgp said:
...the WC was never used in an S10
Almost true. They could be found in '93s. I've pulled several.
I think an Fbody version would fit better in a Gbody though.
your right about the 93, and it's on the list I have with the model numbers and I just never went down that far on the list... 🙂
