Hello gang--anyone else notice that the tach on many G-body Cutlass's doesn't settle in at ZERO RPM when the engine is OFF? I know mine doesn't and whenever I see pics of instrument clusters other cars, I notice how there's don't set at ZERO either. Mine usually sits around 1500 RPM. Is this pretty much inherent on all 83-88 Olds Cutlass's? Is there a fix for this?
This of course leads to incorrect true RPM readings when the engine is running--as I just found out after having my car dyne tested and tuned in preparing for an upcoming emissions test.
Anyway--just curious if others have this issue and if there is a simple fix for it?
