tachometer not working right
olskool
Sep 26, 2021
90
136
33
67
on my 1986 monte carlo ss the tachometer is way off, running up faster than the engine. i put on a tried tachometer filter from dixie restorations. that did nothing. does anybody have an idea? help will be appreciated, i am a professional transmission man, if you have a question just ask.
thanks mike
Reactions: 83MonteCarloSS
Olskool, several years ago, I added a resistor to the tach circuit board which restored functionality to my device. I can't recall the value of the resistor, where to install it, etc. If you do a search of this site on repairing stock tachometer, that information should pop up. Just so you know, the cost of the resistor was less than $1. Good luck!
i have a unified crossfire cap on the accel distributor, would this cause this sort of problem?
thanks mike
Tach on my 79 Calais does the same I was told there is a switch on the tach for 4 6 and 8 cylinder settings mine has been that from when i bought it Dec.78 but have yet to pull the cluster to find out for sure maybe this spring
How far off is your tach? Mine is off in my 83 SS but cannot remember how far. I think 200 - 300 rpm. I didn’t find out until my new distributor went in. The new distributor links to my phone via Bluetooth and has a tach in the app. I haven’t looked into fixing it yet.
My 86 Cutlass tachometer was erratic. I soldered the tach shorting adapter to the circuit board per Olds bulletin # 86-6-135. I did this probably 15 years ago and the tach still works fine,
Reactions: olskool
