I own a 2006 Ford F150 (I know I know I should buy a Chevy). For the past few months I have had a very load metal on metal screeching noise coming from the front and rear wheel areas. I have taken all 4 wheels off and inspecting for damage and have found nothing near the calipers, wheels or rotors.
The sound seemed to have started after the front breaks were replaced. An initial thought was the break pad speaking, so they were removed and anti squeak was placed on them. This didn’t seem to help either. Initially the sound first started only when coasting (at a stop sign or pulling into a parking spot). Now it does it at 80 mph so it has continuously gotten worse. I took it into a local shop in town and they told me that the rotors were warped and they needed replaced. Instead of replacing them I had all 4 of them turned. This did not seem to help the situation. The sound does not happen all of the time that is why I am thinking the rotors are not the problem. Nothing seems to make it start or stop. When the sound starts I have pushed on the brake pedal to see if it changes the pitch or causes the squeak to stop and it does nothing. Doesn’t make the sound go away, or get louder.
I am completely lost as to what could be causing this. Any suggestions?
