No, the kick down cable does NOT have to be hooked up, I have not had it hooked up from day 1 (when i put the engine and trans in the car) and it was shifting great for over a month, but then the governer got stuck, and sence then the trans wont shift right (as i said before, i did fix the governer).
And the kickdown cable mainly only controls down shifting, and sometimes will keep it in gear longer when under full throtle. And if it is unhooked, you want to set it to a no throtle setting or it will downshift early, and it will hold the gear way longer then normaly nesacery.
Also i have run mainy "street-strip" cars that did not use the kickdown, and have never had this problem.
