TH200 speedo cable issues
Daca214
647
829
Jupiter, FL
Has anybody else come across the issue i am having. I replaced the speedo housing with an aluminum one and a new speedo gear and the square hole in the gear almost looks too big for the speedo cable. I hooked a drill up to the cable and the speedometer inside works. Its a new one piece cable as well? Am i missing something?
Oh and it wont stop leaking
This is the housing and gear i have
3ADA039E-4DB2-437D-A92E-E63F5C28F8E6.png 4359E211-B2EE-4FF5-8746-450CD639DD50.png
Im not sure what else i need to change
69hurstolds
8,198
17,600
Where is it leaking from? Sounds like you got a bad or misaligned seal?
There may be a separate square metal tip that may be on the end of the speedo cable. I say MAY be. Not all of them used them. Sometimes the bastages were plastic as well. Did you check for that on the old gear? Did you compare the holes on the old gear and new gear?
Daca214
647
829
Jupiter, FL
Hey sorry i took so long to answer
Its leaking from speedo gear. I have all new o-rings and everything. Unless transmission itself is damaged somewhere inside
My dad mentioned a small adapter he saw back in the day that goes over speedo cable to fit in gear. I cant find it anywhere online. I think thars what i need
Is that what you mean by metal tip?
It was never there on old or new and it always leaked. Previous owner globbed a ton of gasket putty type stuff to stop the leak
69hurstolds
8,198
17,600
You got pictures of the old and new speedo gear holes and housings? Along with the speedo cable end? It may help with perspective. It's hard to know what we're looking at if we can't all see it.
Daca214
647
829
Jupiter, FL
Dont have old but i will take pics of new tomorrow. I plan on pulling it out anyway. Trans is on the floor in the garage so now is the time to get it squared away
Daca214
647
829
Jupiter, FL
Sorry it took so long. I didnt have time to mess with this
Here are some pics. The speedo gear sheared right off in there. Something isnt right. Not sure if i got the wrong gear or what
565bbchevy
9,614
12,683
Michigan
I don't know about the 200 but on the 400 turbo there are two different sized speedo gear housings and the one you use depends on which gear you use.
Wageslave
1,750
3,341
My 200C uses the bullet style speedo drive, so YMMV, but when I regeared mine the new gear would not allow the speedo cable to seat fully. This caused a LOT of bind in the speedometer cable, and would not allow the cable to screw fully on. This also shoved the shaft of the gear into the transmission, which could have sheared the shaft off of the gear.
In my case, I found the tip of the speedometer cable was about 3/16ths too long, and would bottom out before the ferrule would seat against the gear. I dremeled the excess off of the end and reinstalled the cable, and didn't have any more issues.
GroceryGetter83
LS Mafia
676
2,406
Tampa, Florida
I think that silver piece is what I need too. The square hole in the TH400 speedo gear looks too big for the Cutlass speedo cable
