Th350 vs Thm250c, whats the difference?
ck1984
Sep 19, 2021
52
24
I have an 84 cutlass supreme brougham. I already swapped in a 5.3L truck LS thinking i had a Th350 like typical specs showed, but i guess having a canadian sold or built model i seem to have the weaker (M31) TRANSMISSION,AUTOMATIC 3-SPEED(THM250C)
Not sure if i just got lucky but it bolted right up and has been driving flawlessly for 2 months now.
Anyways i cant really find online if theres any difference between the 3 forward gear ratios or are they exactly the same?
whats all different ? someone mentioned 1 less clutch disk and band?.....
if i blow this transmission and want overdrive is it better to go with a 4L80 even though i would have to re-add the wiring?
or will a 2004R also bolt up to a 2002 5.3 L Ls?
is the 2004R same length as th350 and save me a new driveshaft by chance?
8,826
7,779
The 2004R is dual pattern. It is not strong in stock form. Over 400 ft/lbs, a $400 US billet forward drum is needed. The 4L80E needs a controller of some type, wiring and the drive shaft to be cut. A good used 2wd 4L80E go for at $500 in Saskatchewan from what I have seen. They handle 600 ft/lbs with a line pressure mod.
g0thiac
939
582
I had no idea the bellhousing for the 250C could fit LS engines like that.
But the TH350 I think came in different lengths so idk.
8,826
7,779
I assume the sbc and LS have the same bell housing pattern? Our cars came with the short 6" extension. The major difference between a TH250 and a TH350 is the TH250 uses a band to apply 2nd gear. The TH350 uses a sprag and a clutch. It also has a band but it is for manual downshifts. I actually fried first. I didn't realize it was missing till ran the 1/8 mile. Talk about slow times but I didn't cook the second gear band, launching with slicks.
ck1984
Sep 19, 2021
52
24
HAHA, i had no idea there was such a thing as THM250c let alone fit my LS engine.
i think the LS has 5 or 6 boltholes and only 4or 5 lined up but thats supposed to be perfectly ok.
ck1984
Sep 19, 2021
52
24
So whats the 1st to second gear spread like on a 2004R? What should a used one be worth in saskatcheewan? and a rebuilt one would be how much more?
Yes ive seen several used 4L80s under $500 in saskabush.
you still have the RIP 88 cutlass?
8,826
7,779
No, I let the 88 go, crushed. It was getting rough and no Classic license being a 88 and there never will be. Both cars were getting neglected, the 70 is worth more and costs me $140 a year to license. I buy a 87 442, which I almost did, it will cost the same. I will pick up a H/O or 442 eventually. The gear spread and ratios are the best of any 4 spd OD. The D9 which any non performance core seems have flash stalls around 1900 rpm, 300 more than your TH250C will. Be aware, some including the last one I bought shift 3000 rpm at full throttle. The small weight needs shaved to raise the shift points. I paid $400 for a 73 Olds 350 and a good 2004R. I see them for $150 to $200 on Kijji.
doood
Amateur Mechanic
Sep 24, 2020
581
794
I had the THM250C in my 84 v6 Monte, and I gave it away with 21000 miles on it. Tried to offload it at the transmission shop, and they said they couldn't use it. If it had been a 2004R, I'd have bolted it up to the 5.3L, but with only 3 speed and nearly certain destruction behind the V8 I didn't bother. The only thing I could have used it in would have been a cheap flip down the road.
5,711
12,220
250C is not worth the time to hook it up to an LS or anything else. It's not worth the the effort. They suck balls.
A 200-4R needs a couple of upgrades to be reliable, just the same as TH350. Decide if you want a 3 or 4 speed. Bulletproof is a TH400 (3 speed) or 4L80E (4 speed).
I understand budgets and being cheap, but a 250C is not worth the time to bolt it back in.
Ribbedroof
4,905
7,013
Wellston, OK
Despite the heavy performance bias on this board, i have found the TH250C to be a capable trans behind a stock 305 as a daily driver-type trans.
Would I use one in any kind of performance application? Nope, but for that person that just needs a working trans, they're "OK". Still better than the TH200/C
