Good morning,
I have a 1984 Oldsmobile with a Mild 455 and TH350C Transmission. The transmission has failed to the point where it will not engage in either forward or reverse. I am considering removing the TH350 C myself for the purpose of having a local shop for a re-build it. It is my understanding a TH 350 C should have stall capabilities. This was working when the old 307 was on board. However, this was abandon and not dealt with when the 455 was installed. (Maybe that is part of the problem with the TH 350 C since it was not allowed to lock up as designed?) It may be important to note the TH350C was installed in the early 1990s after the old Turbo 200 failed.
Questions:
Can a correctly built TH350 C handle a mild 455?
What should be done to make the transmission lock up correctly?
I suspect the torque converter is trashed since I believe it came from the old Turbo 200? What would a proper touque converter set up be in terms of stall etc?
Thought:
The rear gears are standard highway from the original vehicle set up. The rear end may or may not handle the power of the 455. I really don't have the money for a 12 bolt or a ford 9 inch. I wish I could upgrade this.
I appreciate any thoughts or input. Thank you for reading this post.
Questions:
Thought:
