I really have some homework to do. I will take some time to try and figure out what the best option is. I do not know a great deal about transmissions/ rear ends/ gearing. My learning curve will be steep. Hopefully I won't test everyone's patience.
Is a 350transmission mechanically the same as a 350C? I know the TH350C is supposed to have lock up capabilities. I suspect a standard 350 does not have this capability? I do like the potential lock up capabilities from the 350 C.
This assumes I understand how the locking torque converter works. My understanding is the torque converter locks up at a specific RPM after entering 3rd gear. This allows the transmission and engine to spin at a 1to 1 or near a 1:1 ratio. (I may be exposing my ignorance here.)
Is there a resource for comparison of weight and gearing ratios for various transmission units such as the TH400, TH350, TH350C, TH2004R, 4L80E? If not I can try to put something together for comparison. I also need to ID what gears are in my current rear end. If I'm going to take the time to do the research on weight and trans gears then I might as well understand how gearing in the transmission translates to the rear end. I may not have the cash to purchase what I want now. But I can at least make an informed decision. I'm going to ID the rear end shortly.
