BUICK The Final Objective (Mission Accomplished, 7/23)
Without knowing what measuring tools your using, I'd get a second opinion. Haul the block with main caps and bearings installed/torques, rods and pistons with rod bearings installed and the crank to a machinist or trusted engine builder to re-measure. The worst thing that can come of this is a crank polish/minor cut. More crank work is what I was leaning towards, but I would also like to get a better dial bore gauge and see if maybe I can fine some different bearings. When measuring everything apart, mathematically I have a .002" difference. So split in half I would have .001". But when I put it together that space isn't there. Gotta finish measuring the rest first, then I'll seek the solution I guess.
I would NOT put it together too tight. And being tight is better than being loose - easy fix. Agreed.
Have you tried checking the bearings with some plastigage to confirm you micronometer readings? I have some but haven't used it yet.
How did the orginal bearings look? Maybe incorrectly marked bearings? Were the rods resized, I assume? I know Buick 350 like tight clearances but that sounds really tight. The rods were reconditioned to true-up the bores. So modifications were made there. All of the old bearings were marked ".010" and the crank journals measure 1.990 and 2.990 respectively. Yes, it is far too tight.
I use plastigage to confirm what the machine shop has measured. I’ve had to haul everything back once - it was pita, but worth it.
Logging in to post that the car runs and drives now. Got it started in July and am still breaking things in. I have more pictures and video than I can shake a stick at, but no time to shake a stick at either. Thus far, thumbs up on the TKX trans, and good review thus far for Johnson lifters. The new build is starting to hit its stride and I'm at a weird point where I'm both really enjoying what I've accomplished, and also feeling like there are no big plans left aside from keeping what I have alive and well. Lots of rust repair in the future... It's been a long and expensive 9 months of research, worry, long days, and frustration. But I'm as happy as a 6 year old me in a Pizza Hut at a "Cruis'n USA" machine.
hot damn
Reactions: 307 Regal
Awesome! I am really want to go the TKX route on my 70 Cutlass S.
Congrats, very glad to hear
