The welds look good to me, Donovan, nice work!
Damn, I might be getting to the point where I’m good enough to not have to grind down all my ugly-assed welds!
What you have done is short of miraculous. Congratulations on a superbly done project. My only remark comes from observing the Hooker headers which look like ones I long time discarded because one pipe on each side went inside the fender well and severely cut down on my turning circle, and my front tires scrubbed the hot pipes each time I tried a simple parallel parking maneuver. How did you manage to avoid this problem?
Looking good man! I might have missed it but what are you using to brake the metal? Im assuming something with some removable fingers?
How big is your garage?
Standard double car, 24’ x 24’. I try to use every inch of space to its maximum efficiency though.
Appreciate the accolades, thank you.
Actually if you go back through the thread, you will find that I added some adjustable steering stops to the lower control arms and locked them down just before the tires contact the tubes. But to be honest, I very rarely ever made contact with them the entire time I was driving it. Certainly not during regular driving conditions. It’s not a daily driver either though, so there was never a need to parallel park.
You actually discarded those headers? That may have been a grave mistake, Hooker no longer makes them and they can be pricey if you do happen to find a good set. If you still have them, I might be interested in purchasing them from you just to have a spare set in case I ever damage these ones.
Thank you!
You didn’t miss it, I mentioned bending in my metal brake but have never posted a picture of it. It’s nothing too fancy, just a 24” box and pan (and yes, with removable fingers) mounted to my bench top.
