Thank you, Donovan, appreciate it!Done and done, in the update above ^^^ Mike.
Now I see what you mean about the fuel hose clamp/separators Donovan. Nice stuff! Way better than the zip ties.
How do you plan to approach your bump steer?
Say hi back! Miss him around here, along with a handful of others.....Also, I’ve been in contact with Turna about the Sick Speed Monte clutch pedal bracket, I should probably say hi to all you mongrels from him.
Years ago after a spindle swap on my 84 I quickly noticed a quirky shift of the front end in large dips. Since I have unlimited use of an alignment rack I decided to set it up to see the actual movement of toe change. The toe change I seen on the computer screen pretty much confirmed what I felt on the road. Several hrs of removing and reinstalling the drag link and lowering the inner tie rod in increments I found the point where front end lift turned from toe in to toe out. Close to that the point toe change from slight front end lift to slight compression was lowest I was able to achieve. I then welded the inner mount solid onto the drag link. The quirky front was gone.
Forgot to mention I have the unpopular b-body spindles. Actually I used 11in b-body for a few yrs but switched over the similar 12in astro van spindles.
I certainly will Rick!Say hi back! Miss him around here, along with a handful of others.....
