Hey guys, it's been a bit since I last updated, but I've been trying to spend less time at the keyboard and more time getting my hands dirty if you know what I mean...
Continuing covering the frame mods.
With the front section of the frame pretty much complete, the focus was shifted to the rear, starting with the rear crossmember. As with the rest of the frame, all the unused holes were welded up, and the welds for the upper control arms were re-done to start.
As you can see from this cross section pic, the factory mount is quite thin and weak. Improvements were needed here.
A pattern of the mount was traced onto cardboard, transferred to steel, and cut out. Holes were drilled for the mounting bolt, as well as in multiple spots for plug welds to keep the two together. The bolt is there in the pic to make sure the orientation stayed correct during welding. The factory mount was roughly 1/8" thick, and the addition was another 1/8" thick, equalling a 1/4" thick mount when completed. Much stronger.
This pic is a bit deceiving, it looks like there's a gap between the two pieces, but in reality the edges of the material were beveled to allow for good weld penetration and a nice strong weld.
This is a later pic with the rear suspension mocked up, but you can see the completed reinforced mounts visible in the background. Note the QA1 Lift bars in place on the diff housing. Keep in mind, this car is now on Air Ride, and when the car was aired down, I was concerned there might be some interference to the frame, especially once the control arm lengths started being adjusted for pinion angles, etc. So...
...the top of the crossmember was notched and flanged for strength for clearance around the upper control arms in the lowered position.
With that completed, the focus was shifted to the lower control arm mounts. The frame was stood up on edge and supported with tie straps hooked onto eye bolts I threaded into the ceiling. This gave me the perfect angle and access to work easily. A hollow section of boxed tubing was cut just slightly wider than the width of the control arm and bushing, and bolted into place. This ensured that the width didn't close up on me while all the welding was being done.
Pieces were patterned and cut out of steel to make up the top and edge of the lower mount, and tacked in place.
They were then burned in and dressed down.
