This can be a varied answer. I can tell you what I have and what works for me. That doesn't mean it will be your best choice though.Well, been doing some looking around and comparing, think I have it narrowed down to 2 possibilities:
UMI naturally:
1978-1988 GM G-Body 1” Tubular Rear Sway Bar, Chassis Mounted, Pro-Tour - UMI Performance Inc.
UMI’s G-body Pro-Tour style bar is a true multi purpose high performance rear sway bar. The chassis and differential housingwww.umiperformance.com
And RideTech:
Rear Sway Bar | 1978-1988 GM G-Body
Ridetech has upgraded the traditional notion of sway bars with the new MuscleBar™. Using precision CNC tubing benders, PosiLink end links and Delrin lined mount bushings, Ridetech can now produce sway bars with unheard of dimensional and rate accuracy. FEATURES • Precision CNC-Bent Tubing For...www.ridetech.com
Both are close in price and features, the shipping time is much better on the RideTech kit, it can ship before the end of the month through Speedway Motors. UMI isn’t expected to ship until sometime in December. 😠
Streetbu, scoti, UNGN, melloelky, motorheadmike, where are you guys? Still looking for input and feedback if anyone has any experiences down this road.
I'm running a factory rear sway bar and a F body 36mm front Bar. This seems to give the car a decent balance for me. If you go too stiff on the rear bar, you end up being very twitchy while cornering and have a tendency to snap the rear end free when least expected.
From everything I've ever read, most G bodies do best with either no rear sway bar, or just the stock rear bar. Mind you this is for cornering not drag racing. Too stiff a bar upsets the balance and the chassis
