I bet you gals want the gun...
the LOOOOOOOOOOOOOOOOOOOOOOOOOOVE GUUUUUUUUUUUUUUUUUUUUUUUUUNNNNNNNNNNNNUUUUUNNNNNNN!
I think it was originally grandmas car, that got donated to a local high school, that was acquired by the guy I got it from so I dont think it had much more than the 84k km or so on the odometer. The bad master cylinder is what I think saved it, seems people thing that's a big job to replace or something.
It can be depends on frozen bleeders etc. The Master cylinder is dying on my 70s. That means annoying bench bleeding, plus bending one line, I need to change the rear wheel cylinders and one line would not budge with mild heat. It can be a many hour job plus either a vacuum bleeder or an assistant. Yes, I have swapped one before🙂.
I'm thinking about it. I have 3/4 of an inch of overlap in the metal still so I can go that way. I'm a LOT better at welding than bodywork, that has me leaning toward a butt weld but I have some time to think about it. I mean it's only been cut out for 2 years already... lolLooks great. Consider flanging that quarter patch instead of butt-welding it. If you aren't Donovan skill level, you'll end up with far less distortion with a flanged repair. Just my unsolicited $0.02.
Pretty big update today.
C pillar and roof restoration has begun.
I started off by addressing a couple of holes from the Vinyl top that were from the factory rivets.
Now you see them, first one patched.
Now you don't. Had the get the welder all unpacked and set back up with some 0.23 wire, but it was very quick work.
Then I moved to the big ticket item. The C-Pillar that i uncovered 2 years ago.... first step was wire wheel and 36grit prep. Cleaned them both up, double checked the lines to make sure I really did have them nice and lined up with the body lines.
Then I went to the bench and mixed up some fiber filler that I picked up last week. I had been contemplating using AllMetal filler, but did some deep digging and decided I wanted something with a little more flex. I'm going to flex the body hard so a harder product like AllMetal was probably going to pop out. After some conversations with The Rktpwrd godfather and some online research this is my direction.
I am not a body guy, I have not done any body work before. This was the first venture. So I read the instructions.
I didnt lay on too thick, I wanted to end up slightly under finished surface so I could give it the "Oldscool" multi-layered finish. And it worked out really well. I think anyway. After the prescribed drying time, I hit it with the DA and got both sides down to just noticeably under a straight edge on the sheetmetal. Stage one complete.
View attachment 130298View attachment 130299
So far so good. This took a couple hours as I was being cautious and making sure I had it done right. After the Rktpwrd approval of the texted pics of the work I carried on.
I didn't remove the headliner, the rivet holes took about 3 or 4 small tacks to fill, so heat was very minor.Just curious, did you remove your headliner inside before welding the rivot holes? I need to do the exact same thing to my regal and I wasnt sure if I should remove the interior first because of the heat.
thx
