gwhiz said:what about the lines.I am not racing it but has to be reliable for the street.Is it better to cut and splice or use an fittings and braided hose?dont want to be cruising and blow off a line,will just hose clamps handle the pressure of everyday driving ?
pontiacgp said:Make sure you run the transmission fluid through your radiator before your cooler or you have a good chance of running the fluid too cool. The coolant in the rad heats up the transmission oil to it's running temp. If the oil is too cool you'll destroy the transmission prematurely.
I thought the cooler the better when it comes to transmissionspontiacgp said:Make sure you run the transmission fluid through your radiator before your cooler or you have a good chance of running the fluid too cool. The coolant in the rad heats up the transmission oil to it's running temp. If the oil is too cool you'll destroy the transmission prematurely.
FE3X CLONE said:pontiacgp said:Make sure you run the transmission fluid through your radiator before your cooler or you have a good chance of running the fluid too cool. The coolant in the rad heats up the transmission oil to it's running temp. If the oil is too cool you'll destroy the transmission prematurely.
I've heard this thrown around quite a bit but does anyone have actual proof of what too cold is? I have NEVER seen this with any of my vehicles.
Heck, it's been 0-5*F a few days here and my '08 GMC's transmission doesn't make it much above 100*F and that's how GM designed it and warranteed it apparently...
