If it started and ran already just run it with some good oil and a good quality oil filter.
Any damage that was going to happen already did when the old owner started it.
I would worry more about the freeze out plugs and leaks.
like i said keep an eye on the TEMP gauge, or replace the thermostat
Well in another post I mentioned a possible water leak with the freeze plugs.........so we shall see. There's an ulgy sort
of water inlet on top of the intake manifold at the rear of the engine. It has one of the radiator hoses connected to it. It
may have been the culprit to be leaking when I noticed the water running off the back of the engine on visual inspection at the sellers
place. The hoses seem to be of that age that all need replacing and didn't give the freeze plugs a second thought...until after I
bought the car. I hope it's not the freeze plugs. Considering the car spent all it's time in Tucson I'm hoping it got through the winters
without being subject to any hard freezes we have here. They happen but not that frequently.
