things a narc would say for $100 Alex..Is this a Trick Question? You're not a Narc, are you?
And just so you know, there were some 69 Camaros that came with A.I.R. pumps. 🙂
sigh....
It's been a long time since I've done one, but they're not that tuff. PITA to get to, though.
Apparently you haven't really looked this over real well yet or you'd see it's not that tough. Get a 3/8" breaker bar. This is for the adjuster square hole on the end of the bracket. You'll need this to pull up on the A.I.R. pump bracket to put the tension on the belt.
I don't recall the head sizes, but there's the bottom swivel bolt for the A/C compressor. It's a through-bolt with a nut on the end. This is also the top swivel bolt for the A.I.R. pump. You loosen that a little bit. No need to remove. 15 mm comes to mind, but don't quote me on that.
There's two plates for brackets, a forward and a rear, to this thing. On each, you'll see an arc slot for adjustability. There's bolts on the head (right next to the fuel pump- the REAL PITA bolt) and there's also one right about behind the A/C belt on the bracketry itself. Loosen these and the A.I.R. pump should move easily. These may be 14 or 15 mm bolt head size. But again, don't recall for sure.
Use the breaker bar to put the proper tension on the belt, then tighten down the front bolt behind the A/C belt. Very snug. This should hold everything in place until you can tighten the rest of the bolts. It's better if you have a helper to either mess with the bolts or put tension on the belt.
That taxed my brain without going out and looking at it again (I know it's been years since I've even bothered to look), but I believe that should get you where you want to be.
If I remember, I might take pictures when I go out to the shop again.
But if you have one, you can sell it to the 69 Camaro crowd for big $$. Even if it doesn't work.I know and CARB doesn't care. They are not required to work.
