You wrote: "the pulley mark was about a 1/4 inch completely about the tab...theres something to ponder"
Do you mean that the balancer timing mark was advanced all the way beyond the timing tab? (to the left when looking down from in front of the engine)
Did you check the timing with the EST (4-wire) distributor harness connected or disconnected?
Was the engine at operating temperature?
Does your car still have a computer-controlled distributor?
If your distributor has been changed to a conventional (non-EST or computer-controlled) distributor, the correct initial timing could be more advanced than 6 degrees BTDC.
