I have a backfire in the exhaust, not through the carberator at all rpms. Started at square one with firing order and plug wires. Found that the wires are off by one post but the car was running and decently minus the backfire. Switched to normal location and it won't fire. Returned the wires to one post off and checked timing. According to my light, I was 53 degrees BTDC on base timing?!?!? Adjusted to 11 degrees and the engine ran terribly, no throttle response and wanting to die. Brought to TDC 1 and pulled the cap, I am dead center between what is now 1 & 2 (remember the wires are all one hole off in the clockwise direction). Where do you recommend I go from here?
