To frame notch or not?
I used the UMI kit but honestly if I were to do it again I would just use the part cut out of the frame and recess it and weld it up and save $100.
If I had a couple of years more experience I would try that, but UMI is just a couple counties away so I’m going to buy their kit.
That being said, did you think the plate thickness of the kit was too light, or was it heavy enough for you to be confident in it?
You'll want a good 6 or 8 quality jackstands, and some metal shims. You need to lift the whole car in the air, and support both in front and behind the notch areas on both sides, as well as the front of the car. You'll need to use the metal shims to level the car once it's in the air and off the suspension, both left to right in the front and rear. Metal shims won't compress from weight.
Aside from that, if you saw how flimsy the frames are from the factory you wouldn't be worried about weakening it with the notch. Just good welds, thick steel, and box it all in nice
This completely slipped my mind- where did you check level length wise on your car? The frame rails under the doors or somewhere else?
I used the under door with the short magnetic levels. The left/right is more important than the front/back if you're working one side at a time and not cutting all the way through.
Reactions: UC645
This is how I did the wagon. Sh*t simple.
I'll do the Monte this Winter, full notch down to inner wall and relocate the tubs in board. Reinforcing where needed.
I didn't pull the wagon apart to do it. Doubt I will with the Monte either.
295's with room to spare
Now THATS what I’m after. The 8.8 swap and it’s wheels might throw me off a bit, but if you’ve got 295s under a Cutlass, I think the Montes can take the same with a similar notch.
Although looking at my wheelhouse, something’s off. Is the seam where the inner tub meets the trunk floor kicked out slightly?
Reactions: Tony1968
Mine was slightly but nothing a little hammer work couldn't fix. Plus rolled my fenders
Reactions: Rktpwrd and UC645
