Torque Converter & new 350 / 290 hp engine
If that motor has Vortec heads a 3000 stall, 4.56 gears, and a .488" 292 cam will get that thing moving right proper.
Reactions: el camino ss 84
If you do have vortec heads a roller cam from a crate 604 or the ZZ4 which has the same cam works real nice with those heads...
The 290 hp has 8.5 to 1 compression, smog 76cc heads and a fairly big flat tappet cam. Basically a 220ish duration cam added to cheapest 350 GM offers.
The converter is stalling at those rpm (1300-1500) not locking up. Converter stall is when it actually produces forward motion. Lockup eliminates the slippage of the converter via a mechanical clutch creating a more efficient mode of power transfer. If it's actually locking the 'verter at those rpm in low gears it would be lurching and bucking all over.
Converters are witchcraft and voodoo. So many things change how they act and perform under specific conditions.
I was so excited with your response a couple months ago I forgot to thank you! I appreciate your clear answer. Thanks
Reactions: Turbolq4
