To answer your original question, I dont think the engine will like 43*, its way too much. I think even 38 is too high, but im sure someone somewhere has a radical SBC that likes it.
Ive always found an SBC to be happy around 34-36.
81GrandPrix383 said:
If I set the total timing to 34 to 38 degrees the car does not run in gear unless I have the idle set to 1300rpms and it keeps running after I shut it off.
Vacuum is plugged into manifold vacuum, not ported but I have tried both and both were plugged off when I was setting the timing.
Sounds like an unrelated issue. 1300rpms will cause your car to run on because the idle is so high. It sounds like the other tuning issues are being brought to light as youre playing with the timing.
A big cam like yours, (assuming the XE274 like in your sig.) will like about 20ish degrees at idle. It will be lopey sound at 10-14*, but it should still run just fine. All DoubleV is saying is, youre setting your timing to total, but youre symptoms are all at idle (initial timing). Its kind of important to know what youre base is at in this case, since thats where your issues are.
Another thing to keep in mind, if you advance your timing, leaving all things the same at idle, you'll notice the idle starts to get faster. If you back off the timing, your engine might slow down again. Lets say your carb tuning, is WAAAAAAAAAAAAAAAAY off, and the engine doesnt like it when youre in gear, or idling, etc... If you advance the timing enough, the idle may speed up, and make it seem like its running OK.
I think you have all sorts of issues in your tune, but its hard to say without being there. Curious to see what you find. Keep at it, you'll get there.
