Hey all, how's things? Those who remember me I've wanted to get back to posting G-body happenings but have been working two jobs lately and staying plenty busy. I've got a question though and I really wasn't sure where it fits in the forum so it ended up here in general. I found an old thread from 2012 on the subject but it was closed so I couldn't post my question there. I'm trying to get as detailed below as I can so I can get some decent feedback about what I'm thinking to do.
I want to tow Pumkinator to races with another 79 Cutlass wagon I have. I've dolly towed My 73 Nova with Pumkinator, with Pumk completely loaded from the front seats back with tools and junk from Utah to Georgia and back without any issues other than dragging booty from all the weight in the back. This time in towing Pumk however I want to use a trailer, which I have prior experience only using my Suburbans. The goal is to get better mpg and have some insane cool factor when I pull in to races towing a wagon with a wagon.
Pumkinator is going on a diet so it'll end up somewhere between 3000 and 3300 lbs. I just got the trailer and don't know yet what the weight of it is, however it does have a 5000 lb axle. It's an 18 ft single axle with an airbag custom suspension built by a company that uses this set up for high end custom trailers. It was a full use prototype for a design that is now in production, I got it as part of the deal to obtain a Malibu parts car and I just used it to haul the complete Malibu wagon body including engine and trans, but no chassis under it. It towed flawlessly behind my '04 Suburban from Phoenix AZ to southern Utah.
The tow wagon is a '79 Cutlass, stock control arms with poly bushings and Proforged ball joints, 1LE F-body 33mm front sway bar, Moog 5660 650 lb springs and Bilstein shocks. Front brakes are a 12" dual piston '98-02 Camaro conversion. The rear suspension has boxed factory control arms, F41 rear sway bar, and 2" drop springs with air bag assist bags that were on a friend's Malibu wagon that was used to tow a 2000+ lb boat. The engine is a 406 SBC with ported factory heads and a custom ground serious grunt cam that should be in the neighborhood of 300-350 hp and 500+ ft lbs. The trans is a TH350 with a transpack kit and the rear axle is a drum brake 7.5 with a Yukon posi center and 2.56 gears. At the advice of the fellow that towed the boat with the Malibu I will strengthen/ brace the rear frame rails somehow, and the hitch I'm using is a class 3 from a 75 El Camino that I modified to bolt into Pumkinator at the rear bumper mounts and the rear frame rails.
Last 2 pics are renderings of where Pumk is headed and the car that I'm building to tow it. Just wanted to get some feedback from anyone that's towed something as heavy as a car on a trailer with a G-body. Am I on track or am I missing something to keep things right side up? Thanks for any info you can share.
