Hey everyone. I've been contemplating installing a tpi system instead of the old edelbrock carb I've got currently. After reading most of the tpi related stuff I've just got a couple questions left all that's needed is a MAF sensor and an engine harness right? The res of the needed stuff is in the upper and lower plenum like TPS and what not. I don't plan on running an egr unless I absolutely have to. I've got an electric pump. I plan on running a mega squirt standalone management system. What else would be needed for the install as far as sensors and wiring. It should be a direct bolt on application right?
