TRACTION HELP
okkk, yea I put a whole fiberglass frontend on it to try to lighten it up and got aluminum heads for the new motor, so hopefully that helps, ill try the adjustible uppers, relcocation brackets if i need them and that tire size that you mentioned, it might be a while but ill let ya know how it goes. thanks for the help!
the reason it would hit too hard is because the geometry will create soo much i/c change that it tries to move the rearend forward and down quicker than the car will move forward. i experienced that as well with my southside machine bars and it hit so hard i broke a u-joint on dragradials on the street. not to mention the car would act like it was lifting the rear of the car like 2 inches and the tires would run into the front of the rear wheel wells.
monte olrac said:
If you use v6 springs up front it will transfer weight qicker at launch also
true, but they will compress again quickly and should be used in conjunction with a comp 3 way shock in the front.
even on street tires my car hooked up way better on the track. i would take it there and see what it does
Just a question. Why do the V6 springs help?
Depending on your budget and needs (like are you full race?), you could see how deep you want to go. I am full race but stock wheel wells and frame rails on my Monte, here's a pic of my setup. It's a 9" with the adj. upper arms, tubular arms, drag springs, and a single pass. air bag. This setup works extremely well. I have the uppers set to the hardest-hitting setting, and I set my pinion angle I think to 1.5°(have to go back to my log book). The airbag is essential on my car to make it launch straight, i.e. not lift the driver's side higher than the pass. side. Before the air bag, the twisted launches unloaded the drivers side tire. Now the lauches are straight, using 28.5x11.5-15 Phoenix slicks. 60 fts. are 1.48-1.50 all the time.
A huge help for me diagnosing the traction issues I had was having video footage of my launches and reviewing them is slo-mo. Man you can really see what's going on with good video from the track.
On an unrelated note, the video also clued me in to a tie rod problem up front which made me investigate further before disaster struck.
Kevin
hey kevin thanks for your help. the car is mostly going to be street driven. i havent really set a budget yet because i wont be done spending untill the car hooks, lol. i have tubular non adjustible uppers but have been debating on getting adj ones. ive also been thinkin about the drag bag, how much psi do you have in yours. and im gunna be running a 28-11.5 hoosier qtp soon and was wondering what you had to do to get yours to fit(backspacing/rim size) since their almost the same size tire. also what gear are you running b/c i went with a 3.70 since its going to be on the street mostly. thanks alot, joe
