picked one up the other day, largest one they had... 11 x 11.75 inch.
... currently, I only have hard lines running to the factory rad, and the trans runs hotter than I would prefer.
So, here's my question...
- do I run the cooler thru, after the rad?
- do I run the cooler seperately?
- do I run the cooler thru, before the rad?
Personally, it does not make much sense to run the cooler after the rad. It seems this will cool the trans fluid, and then run into the hot rad to warm the fluid back up...?
Running it seperately makes lots of sense, but will my dual electric fans be able to cool both the rad and cooler? I will be mounting the cooler infront of the rad. I do not have an air-dam, and so my rad already has trouble getting air to it. If I run the cooler seperately, what is a good clean way to drain the fluid from the rad, and plug the lines?
What are the Pros & Cons of each setup?
Who else is running a cooler?
How do you have it setup?
Please comment...
Thanks,
Please comment...
Thanks,
