I am trying to put a factory crossmember for a 350 trans in my Cutlass and it is not fitting right at all. I can get it bolted in and the mount lines up fine, but I can only get one bolt on each side to go in. At first I thought I had the wrong crossmember, but I took it back to the guy I got it from and we tried it on a g body frame he had and it fit perfect. The mounting points on the frame for the crossmember are different on my car than the one we tried it on. Mine is an 84 and it has the mounting points for a 200/350 trans and the 200-4R trans. The one we tried it on was from a Monte SS and did not have the mounting points for a 200-4R if it matters. One thing I noticed is that the frame for the Monte had more mounting holes than mine has. I also believe the actual mounts on the frame are completely different than mine. Not sure in what way, I didn't get any measurements or pictures of his frame.
Here are some pics. They were all taken from the passenger side of the car.
I can get the mount bolted up with the crossmember sitting like this.
Kinda hard to see, but the bolt hole towards the front of the car is not even over the crossmember mount.
This is on the passenger side. You can see that one hole lines up.
From the passenger side again. The other hole does not line up.
My question is, was there any different set ups for the crossmember mounting locations? Did they use a specific crossmember and that is why mine is not fitting right, or is it supposed to just use one bolt on each side?
