Trans install and car won’t move
1320John$$$
951
2,043
Pennsylvania
Put it up on jackstands clean everything real good add a quart of fluid start it up put it in gear crawl under the car watch and wait for the leak
8,195
17,596
Fuggin' cork gasket....I would get a fiber gasket if possible. IMO they're better. Less likely to crush/split. Get the pan sealing area clean AF and dry AF first before installing. Proper torque. Check the pan for flatness/gouges/dents that may prevent sealing.
Supremeone
Feb 23, 2020
55
49
Toronto, Ontario, Canada
I’ve been too busy and frankly just needed a break from it but I’m going to be working on it today to hopefully get it figured out. Not leaking anymore so obviously the fluid level is below the leak culprit now
8,195
17,596
Good. You're right, though. ALL engine/trans/rear end leaks, when left alone, will eventually stop on their own. :)
Now get in there and fix that thing!
5,704
12,215
