TRANSMISSION BOLTS KEEPS LOOSENING UP???'s
I use Hylomar blue with a gasket to seal my aluminum trans pan.
Reactions: dickeymoore
Trick a freinds day showed us back in the late '80's was to use a thin coat of thick grease to hold the gasket to the pan regardless of type of pan used. He had a can of military automotive/artillery grease that was perfect for this. He always said not to use any "glue" sealant cause it might make its way into the fluid.
Grease no thanks, you want a non-setting sealant for this application and I have tried RTV's but in the end found the Hylomar blue to work the best in this area.
