transmission crossmember
waxman
2
8
dover del
i got an 86 cutlass salon i was told it was a 3.8 car. the car had a 455 in that was removed and now i have installed a 307 with 350 trans .my problem is the crossmember which is the original one from the car is about 6 inches rearward from the mount on the transmission. since i didnt remove the original engine i hope i have bolted it back correctly i saw a picture of one and it looks like it goes diagonally instead of straight across any pictures or ideas would be helpful thanks in advance
pagrunt
9,167
15,346
Elderton, Pa
From what you know, did the 455 have a TH400 behind it? If so that maybe a TH200-4R crossmember that was used for the TH400. With it being an '86 it will/should have the proper mount positions for both crossmembers, it could be the the TH200/TH250/TH350 crossmember mounted in the wrong position on the drivers side (rear is for the TH200-4R, front is for the TH200/TH250/TH350.)
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
I think an '86 Cutlass would have had a 200-4R. Most people have the opposite problem, nothing to bolt the TH350 crossmember into that far back on the frame rail when swapping in a 200-4R. In the photo below, I added an extension to make this swap. Your cutlass probably has the two holes on a pad close to the foreground. Just curious, does the 86 Cutlass have two extra holes forward on the driver's side? The stock TH350 mounts through the two holes near the jackstand. Can you share a photo?
You might be able to pick up a TH250/350 crossmember cheap from a Forum member throwing it out for an aftermarket double-hump model.
MrSony
6,831
6,741
Des Moines, Iowa
There was a thread about that, 86 cutlasses apparently didnt come with TH200r4s as an option. Someone put that x member in ther for the 455/400 combo. You need a stock TH200c/TH350 x member. Or a jegs, g force, iceman, etc for a TH350.
waxman
2
8
dover del
nope they used the original trans from the car there is another set of mounting hole toward the front of the car on the drivers side thanks for your help
waxman
2
8
dover del
yes it does have the set of holes you refer to when the swap was made the original trans and cross member was used according to the old owner it has snowed here but will send a pic soon as i can thanks for your help
ssn696
Living in the Past
5,546
6,671
Permanent Temporary
Thanks, Timo, for the picture. This is that the TH350/250/200 frame mount for the crossmember looks like with the car removed.
