Can somebody lay out the different types of OD transmissions and what is needed to use them, what is best to use etc? I hate to admit it, but my expertise in transmissions ended with the T-350 and 400 series. From what I understand, the 4L60 and 4L80 are the 350 and 400 with OD. Beyond that I know nothing, do all transmissions require a lockup converter, how do they make them work? I am planning on putting the 450-500 hp 454 out of my 70 in the Malibu at some point and as of right now, my plan is a t-350. But I have been wondering if maybe there is something better that is not TOO difficult to put in and use. So before I pick up a core for a 350, let me know what is out there. Thanks.
P.S. if it matters at all my car has the factory floor console and shifter and I would like to find a way to keep it if possible. I would be open to using a later for example Monte SS shifter for the OD position, but if using the factory shift with OD, Drive, 2 and not having enough travel for 1 is the answer I can do that too.
