transmission line
scarborough
309
66
are the transmission line threads on the 87 cutlass v6 2004r the same as bop th350 threads, not sure of the year
TURNA
Rocket Powered Basset Hound
Jul 24, 2009
10,941
19,992
Socialist NY
Dont believe the v6 ever came with a 2004r
oldsmobile joe
2,067
3,053
mpls
the stock transmission line threads are the same. tube size is 5/16 with a 1/2x20 flare nut. all stock g body automatics used the same size.
565bbchevy
9,614
12,683
Michigan
8,826
7,779
Melville,Saskatchewan
They are the same thread, the angle of the lines are totally different, some bending will be needed. I have swapped back and forth a couple of times.
hoffa65
319
416
Atlanta GA
I believe the flow configuration is opposite for the 2004r from the th350.
Fittings are same size but in and out are opposite ports
scarborough
309
66
thank for the info. the car has a 455 with a 350 transmission with the original transmission lines that's a little hack upped when i got it, the car was a gift, and i assumed the original transmission was a 2004r my bag. i installed a new american eagle radiator from champion. i would like to replace trans line want to make sure i purchase the right lines with the right fitting for the transmission and rad.
