I rest my case. That lug nut isn't going to dry rot and fall apart. Let's consider it an "engineering improvement".sacrificial
I've always considered that a rube move if that's the first go-to. A metal coat hanger stuck in the a broken antenna hole works, too. At least put some grease on the metal-to-metal contact points if you go that route.I rest my case. That lug nut isn't going to dry rot and fall apart. Let's consider it an "engineering improvement".
thanks!It is hokey. When you can get the right sacrificial bushing, don't use a lug nut unless it's an emergency. There's enough parts that aren't made any more that people wish they could get.
Cross shaft bushing is GM part number 1377083 or equivalent aftermarket. Apparently from real-world testing, it takes roughly about 35 years or so for it to wear out.
Only a lug nut would use a lug nut. If you care about your car, fix it right.
Transmission Shifter Lever Linkage Steering Column Cross Shaft BUSHING Only | eBay
Transmission Shifter Lever Linkage to Steering Column Cross Shaft. We now carry the hard to find New GM transmission shifter linkage cross shaft Bushing. Firm up your sloppy shifter linkage with this new part !www.ebay.com
