What kind of gauge do you use? I had a MAC on mine and it bounced constantly, probably 20lbs each way.I had the same issue with the last 2004R. It is probably a clearance issue in the pump. I bandaided it with a .550" boost valve and stiffer spring, brought it up to 220 psi in first and second. Just another example of how finicky the 2004R is.
