custom442 said:not to highjack the thread but...
on a th350, is the hole where the kickdown cable bolted on a high pressure seal/hole?
I can't get a fine/coarse/or metric bolt of any size in there to save my life and I'm not about to go drilling and tapping after the engine's already mounted in.
If it's not a high pressure area, I'm just gunna force in a wood screw :shock: and deal with the tap/thread later if I ever pull it out
(or sooner if ATF starts pouring everywhere)
lol, I had the same problem, but mine was out of the car, I just jammed the bolt I had in there and it worked,
as for the modulator, it will probably pour some fluid out, so just unbolt it, take the otherone in one hand, pull out the old with the other hand and shove the new one in and you will hardly loose any fluid. I just did mine a couple weeks ago.
