vortecs were 96 and newer, but 95 and older can be swapped to carb with a cheaper intake (although not the easiest to find). its from a 87-88 monte carlo, camaro/firebird, and so on as long as they have the centerbolt heads. f body and monte SS were aluminum.
the early 84-90 4 speed autos are 700r4, and after was electronic 700, then they went to 4L60.
if you have a running drivetrain with an electronic transmission you can swap it into your car as long as you keep it injected.
whatever you use, GET THE JET SERVO!!!!!!
my sisters truck has one and it shifts HAAARDDDDDDDD!!!!!!!
harder than a shift kit.
hope this helps.
hope this helps.
