Well, I would like some opinions on what I should charge for my 1979 AMC Spirit project. It will need a rocker panel on one side due to collision damage, has a small hole in the floor and a few small holes in the body due to rust. The body will need paint, but is generally straight and not a rust bucket. It also has a Spirit AMX rear spoiler on it. The engine is a freshly rebuilt 1973 AMC 360 V8 with a Comp Cams 268H cam and lifters, 2.02 dogleg heads, an Edelbrock Performer intake, Edelbrock 600 CFM carb with electric choke, Electronic ignition (debating throwing in the MSD 6AL and 3 stage timing retard box), Milodon aluminum water pump (new), Carter high flow mechanical pump (new), Powermaster mini starter (nearly new) and an almost new set of Hooker Super Competition headers. The exhaust is also new with 2.5 in duals and Flowmaster Delta Flow mufflers. The transmission is a Torqueflite 904 with a factory floor shift and console, and the rear end an open diff AMC Model 20 with 3.54 gears. It has the rare, proper V8 mounts and suspension crossmember, and the V8 Spirit AMX suspension as well. The radiator is a recored stocker with 3 cores in it, and an external transmission cooler. The fan is a giant electric pusher (18 in) and came off a V8 Mercedes Benz and is run off a Bosch relay from the ABS system of a Cavalier. I also removed the A/C from it and replaced it with the proper non A/C heater box. As for the interior, it has a crappy CD player, and the carpet is in poor condition, but everything is there except for the sound deadening which I removed to save weight. There is also a Auto meter monster tach on the column with a programmable shift light. The battery is currently in the trunk in a Moroso box with a cutout switch behind the license plate, but I will probably put it back up front as it never liked to start with the trunk mount setup. The wheels are 15x8 Dodge Diplomat cop car wheels painted Chevy Rally Wheel argent silver with a set of AMC rally wheel centers and trim rings. The whole brake system down to the hoses was replaced several years ago, but probably needs freshening now as it has been sitting for a few years. Oh, the car has manual brakes and power steering.
The engine has never been run and will be installed next week. I plan on breaking it in properly with a few days of sorting followed by a week of pizza delivery before selling it. Yes, there is a ton of work in this car, probably even more than in my Cutlass. However, it needs a lot more too. I will be selling it with all my extra parts including a set of fenders, a door and another engine. So, what does everyone think I should ask for it? Would $3,000 be too much?
