Turbo 350 Shift Kit
shift kit
if i remember right a 200 transmission doesent have a vaccum line to the modulator,it has a tv cable..... the gaskets go one on the valve body you should see a v stamped on the gasket, the one that goes on the case has a c stamped on it ..... if you bought your kit locally you should take it back if you can't read the instructions you don't stand a chance of success!!!! auto zone sells this kit for 35.00 or 40.00 dollars.. good luck 🙂
