They very well could be, however everyone seems to question the factory lower arms and say that aftermarket are lighter and better and in truth with a good set of bushings the factory ones are in most cases lighter and just as strong. Going back to the statement on dirt track cars pure stocks run stock arms and while they will bend in a wreck there are less failures from abuse then you would think and those are extreme conditions out on the track so it does make me question the value of aftermarket arms. Having said that I have use UMI arms before and can say they are more rigid for sure but is it worth the cost when plating the factory arms is so easy?
