pontiacgp said:UMI designs, manufactures and tests their products so why not ask them in detail what the advantages are of using their front control arms. I use their rear control arms and had the lower one custom made for no more than the cost of the extra part. I like their products and their customer service
Thanks GP.
Our front uppers add caster for straight line stability and are available with tall ball joints to improve the camber gain and contact patch. The upper a-arm does almost all of the geometry improvement. The arm is bushed with Delrin (a hard plastic) and prevents the alignment from changing if you lean on the car during hard driving.
The lower arm has a thick bottom pad to accommodate today's hybrid coilovers which are popular in the industry. Geometry is improved when adding a tall lower ball joint and also these arms are available with poly bushings (softer) or Delrin (firmer, super-precise handling).
All our stuff is made in our building and is raced and tested by us.
Any questions let me know on here or email directly [email protected]
thx
ramey
