Around Christmas time I ordered front and rear sway bars and I just can't wait any longer to put them on. I've never done this before though so I have questions. Starting with the front, I have the assembly figured out but I'm confused as to what order the parts go on. In the UMI provided instructions I'm supposed to attach the end links first, then the frame mounts, and hold off on the grease until the car is on the ground and I'm tightening things up. The frame mounts provided came from Energy Suspension and their instructions said to attach the frame mounts first, add grease, rotate the sway bar inside to disperse the grease, and then attach the end links. So which is the correct order?
Concerning the rear sway bar, it came with no instructions. I noticed the mounting holes in the bar are oblong. Am I supposed to center this thing somehow then? I'm assuming I install this much like the front bar in that the car will be off the ground, I install the bar, and I tighten it up once the car is back on the ground.
Thanks ahead of time.
