I'm a little stumped.my question is how does the lamp on the hood function.I know the light connects to a wire that runs to the head light harness from the fuse block.But what makes it turn on?Is there some kind of switch.Thanks in advance for the help
I know mine is powered all the time but the light only comes on when you lift the hood because there is a built
in mercury switch.
I actually mounted two on my hood and wired a switch under the hood to turn them on and off because when I go
full throttle(obviously with the hood closed) they would come on and I could see the light through my hood vents.
The "switch" is part of the lamp. There is a small amount of liquid mercury that makes the connection when you tip the lamp by opening the hood. It has one 12 volt power wire to the lamp and it is grounded to the hood through the base of the lamp. If you have power to the lamp and the ground surface is not rusted or covered with paint then the lamp assembly is probably bad. You can usually find them on E-Bay. Or a wreaking yard.
I bought an under hood light for my 79 Malibu. I see on the hood where it mounts but can't locate where the power connection is. The power wire is about 20 inches with an in line fuse. I'm sure I can locate a hot wire even if I connect it to the fuse box but I would like to connect it where it belongs. Any help is appreciated.
