I have a 1986 TH2004R out of a LG4 305 powered Grand Prix in my 85 Cutlass and it makes some really odd noises. It shifts fine and will even bark 2nd under the right conditions. It sounds like a chirping, squeaking noise in neutral or park that goes away when you pull on the TV cable or put it in gear. It also makes a ticking sound while driving at a steady state speed, kind of like a bad lifter. It's not a lifter though as I just upgraded the cam and lifters and put in all new rocker arms and ran the lash. It also does not tick at idle, just at speed. I have the throttle/TV cable bracket off the GP on it, and even used the right primary throttle shaft on the quadrajet carb for an 80's Chevy, so the geometry is right. ( I currently have an Edelbrock on it, but it did this with the Q-Jet too). The trans has about 20k miles on it since I ghad it rebuilt. Any help would be appreciated.
