Re: **UPDATE**Car will start and die immediately need advice
Pulled off the top of the carb and checked the floats to Edelbrocks spec, they are within spec. I dont have an issue with the car once it is running, its getting the car running thats the issue here. Wondering if the starter solenoid maybe shorting out and causing a short in the ignition system when key is switched from START to RUN?
