Anybody changed the passthrough on the EFI G body fuel sender? I made my own for my dual 450 in tank setup but want to make it a bit less intrusive for this single pump setup I'm putting in my Olds.
The replacement EFI fuel senders have maybe 16 gauge wiring. I'm putting a Hellcat 525 pump in the tank and it has a 18-22 amp requirement for where I plan to run it. The stock wiring for sure isn't up to the call.
Racetronix markets these kits but I don't know if the geometry of the plug is the same as the G body. They certainly look different but they are for TPI 3rd gens and C4's which I assume use the same geometry.
Here is a C4 one
And here is a universal kit
TPI 3rd gen
They come with 14 gauge wire which is again a bit small for 20 amp continuous but I can duel-feed the pump since they are 4 wire.
Any experience?
Here is a C4 one
C44 Bulkhead Wiring Assembly (BCWA-C44): Pump Bulkhead Wiring Systems
Purchase C44 Bulkhead Wiring Assembly or shop other Pump Bulkhead Wiring Systems and Racetronix products.
www.racetronix.biz
Universal Bulkhead Wiring System, 4-Way (BCWS-001): Pump Bulkhead Wiring Systems
Purchase Universal Bulkhead Wiring System, 4-Way or shop other Pump Bulkhead Wiring Systems and Racetronix products.
www.racetronix.biz
TPI 3rd gen
FL98 / F7 Bulkhead Connector Assembly (BCWA-FL98HD): Pump Bulkhead Wiring Systems | Racetronix
Purchase FL98 / F7 Bulkhead Connector Assembly or shop other Pump Bulkhead Wiring Systems and Racetronix products from Racetronix.
www.racetronix.biz
Any experience?
