If Jake buys a Holley fuel tank setup then he's going to take a hit on his fabricobbler status.Another option.
Knock a hold in the cell/tank top and pass through with this. Ground stud on sending unit base for pumps to chassis and 12ga through these. Metripak connected to 8 or10ga for each pump from relay. Under a foot of 12ga isn't going to have voltage drop on 20amps of load. Use hole from stock cable pass through for second 3/8 feed and solder/weld in AN fitting.
You also have a lathe, I would have turned a new sending unit and made a -10 single exit with a -6 return and -4 vent by now with this pass through bulkhead.
ATL Fuel Cells CFD-506 4-Wire Aluminum Wire-Thru Bulkhead Fitting
ATL Fuel Cells CFD-506 4-Wire Aluminum Wire-Thru Bulkhead Fitting Bulkhead fitting for passing electrical wiring through bulkheads such as firewalls or fuel cells. Compatible with 12 or 14 gauge wiring Fitting for two-wires to pass through Constructed of durable aluminum Fuel and air tight seal...www.speedwaymotors.com
I agree that he should make one. By the time he getsthis one made and it perfected for the 2+2 he'll be able to market them (too me) lol.
